ROTATE by reference as default
76jsa
Message 1 of 10
76jsa
is there a way to set ROTATE by reference as default, not by base point?
Replies (9)
Message 2 of 10
SEANT61
You may be able to redefine the command to call some addin program.
Alternatively -
For a rotate with reference call, I use a Right-Click menu entry with the command macro:
^C^C_Select \_rotate previous ;\r @;
May your cursor always snap to the location intended.
Message 3 of 10
Kent1Cooper
@76jsa wrote:
.… is there a way to set ROTATE by reference as default, not by base point? ….
You're not going to escape the need for a base point, in any case, since Rotating by Reference is still necessarily around some base point.  But you could define a dedicated command that automatically feeds in the Reference option after that.  Something like this [minimally tested]:
(defun C:ROTATER (/ ss) ; = Rotate with built-in Reference option
  (if (setq ss (ssget))
    (command "_.rotate" ss "" pause "_reference")
You could  even UNDEFINE the native ROTATE command, and make that the definition of that command name by taking the R off the end of the name.  You would still have standard ROTATE available if needed, by typing it in with the period prefix:
.ROTATE
Kent Cooper, AIA
Message 4 of 10
scot-65
I have a similar utility to Kent's and have named it
c:RTR
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
Message 5 of 10
SEANT61
As a supplement to my Rotate by Reference command macro suggestion, here is a screencast of that, plus another By Reference sub option.  There are times when that sub option functionality comes in handy.  That sub-option macro:
^C^C_Select;\_rotate previous;;\r;@;\p;\\
Message 6 of 10
pl.fischer68
how do you define this command ?
Message 7 of 10
Kent1Cooper
Copy the code and paste it into a plain-text editor such as Notepad.  Save it to a file [call it whatever you want] with a .lsp filetype ending.  In an AutoCAD drawing, use APPLOAD, navigate to where you put that file, and Load it.  The command name is ROTATER [not case-sensitive].
Kent Cooper, AIA
Message 8 of 10
pl.fischer68
thank you so much dude, this rotate command was driving me crazy. Now the ROTATER does work, but it doesn't appear in the aliasedit panel (i'd like to create a shortcut for the new rotater command)
Message 9 of 10
Kent1Cooper
.... (i'd like to create a shortcut for the new rotater command)
I think the command alias editor may work only with actual AutoCAD command names.  But you can make the name of the command anything you want -- the part immediately following  (defun C:  is always the command name, so just change ROTATER to something else [as long as it doesn't conflict with some already-existing command name or alias].
Kent Cooper, AIA
Message 10 of 10
pl.fischer68
amazing ! thank you for taking the time to explain me this, hope it will help others !
