Rotate a line drawing to create a solid
bencharlton5C8EZ
Message 1 of 10
bencharlton5C8EZ
Hi folks
3D numpty here but I routinely find myself banging my head against a problem whereby I've drawn a shape using lines, polylines, arcs etc and I want to rotate it for form a solid.  The problem is that it either wont let me or I end up with a surface rather than a solid.  I try join and or pedit but this some times helps some times doesn't.  I have attached an example which is half the section of a column I want to rotate by 360 degrees to create the solid.
Replies (9)
Message 2 of 10
bencharlton5C8EZ
The really stupid thing is sometimes I seem to do it and it works fine so I dont know what I am doing wrong.
Message 3 of 10
will_young
Have you tried REVOLVE?
Message 4 of 10
bencharlton5C8EZ
Yes, that is the command I am using, sometimes it works for me fine but other times, as in the file I attached for example, it uses the lines to make a surface rather than a solid (or doesn't work at all).
I must be doing / not doing something with the lines.  I try join and pedit/join as I said which sometimes solves the problem but hasn't in this case.
Message 5 of 10
will_young
I think it's based on the mode chosen in the command: AutoCAD 2025 Help | About Creating a Solid or Surface by Revolving | Autodesk
Also whether it's open or closed will affect it:
Open curves always create surfaces, but closed curves can create either solids or surfaces depending on certain settings.
AutoCAD 2025 Help | About Constructing Solids and Surfaces From 2D Geometry | Autodesk
Message 6 of 10
bencharlton5C8EZ
did you take a look at the file I shared?
Message 7 of 10
tramber
The polyline is open.
A good knowledge of their editing is required for 3D...
But we are not far, are we ?
Message 8 of 10
tramber
Get very close and suppres this vertex
Then close the polyline with PEDIT or the properties palette.
That would be my way of fixing.
Message 9 of 10
bencharlton5C8EZ
That's got it, thank you!
Message 10 of 10
will_young
Yes, did you read the link? 😋
