Room wise Data extraction of objects
This is my sample file in which i want to extract data in the form of excel.
I want to extract it in particular format like
Column A          Column B            Column C                            Column D (optional)
Room Name     Room Number    Layer Name of object       Count of objects
Example
Office                 L1-5471               Bulb                                      5
Office                 L1-5471               Light                                     1
Office                 L1-5474               Bulb                                      3
Is it possible to do in cad?
pendean
Community Legend
Community Legend
Are you actually using AutoCAD ARCHITECTURE? you are in the plain AutoCAD forum.
JTBWorld
If using regular vanilla AutoCAD take a look at this https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/Creating...
Jimmy Bergmark
JTB World - Software development and consulting for CAD and license usage reports
https://jtbworld.com
R_Tweed
Provide something in common between the symbols to sort and filter, the more in common the more filter options. You could use layering but then your dwg might get bloated. I would think an attribute would work best in my opinion. I've attached a screen cast to explain. Please,Still working out how to use screencast
This is a sample I worked up using (invisible) attributes in blocks, and the data extraction wizard built into AutoCAD.
Without having your geometry, I just whipped these blocks together sorta close, but they should get the point across.
The dwg and dxe files must both be extracted from the zip file (apparently a dxe file extension is too close to a .exe for a direct upload, thus the zip file) for it to work. See >link< for further info on data extraction. It's a great tool, I use it all the time. I won't say you are limited only by your imagination, but close. (slight exaggeration)
Hope this helps
R_Tweed
Screencast attempt #2
