How to get two road subassemblies to transition smoothly between each other when they change along a corridor?
Link copied
Hi..
You could use dynamic feature lines or leave gap in between and use a dummy assembly with no subassemblies to bridge or transition the gap...
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
@lim.wendy wrote:Hi..
______________________________________________________________If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
I have been trying to fiqure this out for a long time now and would like when you have time can you so me some steps how to do this. Here is what I am trying to do.
Lets say my horizontal alignment starts at staion 100+00-200+00 bc with a curve of 400 which is the ec and then a line 200' at a bearing of s20 15 16 n
My existing travel way at station 100+00 is 11.67' lt and 10.97' rt. My transition at the end of the 200 line will be 12' tw lt and right with a 8' shld left and right. I will have a 3' chocker with a curb.
I have already the assembly created but the transition tieing into the existing is what I cant get.
When you leave a gap in between the corridor assemblies it will only connect on a staight line. This is not a viable solution where the centerline alignement is curved.
Not sure if you have moved on from this but targeting assemblies works well for this but also one thing I have found that is great is a custom transition assembly. See below links:
PointInTransition Subassembly
https://forums.autodesk.com/t5/civil-3d-forum/subassembly-composer-with-transformations/td-p/5931278
NumericTransformation
https://forums.autodesk.com/t5/civil-3d-forum/civil-3d-number-transforms/td-p/7947049
