AutoCAD Forum
Right-click the UCS icon
7 REPLIES 7
Message 1 of 8
fk
1071 Views, 7 Replies
Hi.
When I select the UCS icon and right-click, I get a right-click menu, but there is no options for UCS there. I thought it should give me options regarding the UCS and the UCS icon. Using vanilla AutoCAD 2013. Any idea?
\Freddy
7 REPLIES 7
Message 2 of 8
maxim_k
in reply to: fk
Hi Freddy,
You don't need to right-click. Just select UCS icon (activate grips on it), then move mouse to one of the grips and wait for a moment - you should see multifunction grip menu with options, they will be different for different grips (origin, X, Y and Z axis).
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 3 of 8
nestly2
in reply to: fk
Make sure Right Click Menus are enabled.  Tools > Options > User Preferences > Shortcut menus in drawing area
Message 4 of 8
fk
in reply to: nestly2
"Options > User Preferences > Shortcut menus in drawing area" is checked.
I get a right-click menu but it does not look like yours. My menu looks the same if I right-click in the drawing area without any objects selected. Something in the CUI?
Multifunctional grips is working the way your video shows.
\Freddy
Message 5 of 8
maxim_k
in reply to: fk
Hi Freddy,
As you see on the "video" you have to select UCS icon at first, then move mouse above one of the axis of UCS icon (not above grip), then right-click to call context menu.
You can also check with CUI command - right click shortcut menu section for UCS icon.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 6 of 8
fk
in reply to: maxim_k
It is the same right-click menu if I select the UCS icon or not.
We use enterprise menu (CUIx) and I can see that the shortcut menu in ACAD.cuix (that is partially loaded) has the right settings. It looks the same as your right-click menu in the video (and what I was expecting). The right-click menu seems to work on all other objects except for the UCS icon. Strange. What else to check?
Message 7 of 8
maxim_k
in reply to: fk
Look at this topic:
forums.autodesk.com/t5/AutoCAD-Mechanical/UCS-right-click-menu-somehow-got-disabled/td-p/3624770
It is about AutoCAD Mechanical, but maybe the same could be applied to enterprise menu?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 8 of 8
fk
Thanks. I transfered the Shortcut/UCS to my local CUIx and then it worked. I do not think this is the right way because all my other shortcuts (right-click) seems to work. I assume this is a bug. Anyway, it works now. Thanks again.
\Freddy
Forma Design Contest
