Right-Click Menu
Right-Click Menu
cbohannon
Message 1 of 9
Right-Click Menu
cbohannon
Trying to get back to the normal right click option as in capture 1,    Capture 2 and 3 is what happens now......
Replies (8)
Message 2 of 9
imadHabash
you may need from OPTIONS to control and modify some settings.
Imad Habash
Message 3 of 9
cbohannon
My options are exactly that, still have the same problem
[cid:image001.png@01D33863.A9696210]
Message 4 of 9
cbohannon
IT SEEMS TO BE MORE THEN A RIGHT CLICK PROBLEM. WHEN I AM TRYING TO EDIT A BLOCK I GET THIS ERROR…INSTEAD OF MY RIGHT CLICK OPTION COMMING UP TO ALLOW ME TO EDIT THE BLOCK.
Command: _bedit
c:\program files\autodesk\autocad 2018\acauthenviron.arx cannot find a procedure that it needs.
Unknown command "BEDIT".  Press F1 for help.
Message 5 of 9
paullimapa
If all else fails, try Reset AutoCAD 2018 back to Defaults:
Start > All Programs > Autodesk > AutoCAD 2018 > Reset Settings to Default
Area Object Link | Attribute Modifier | Dwg Setup | Feet-Inch Calculator
Layer Apps | List on Steroids | VP Zoom Scales | Exchange App Store
Paul Li
IT Specialist
@The Office
Message 6 of 9
cbohannon
That did not work either, It is only having this problem in 18!!! AutoCAD 17 and 16 are working fine. I will just uninstall and reinstall tonight. Thanks guys.
Message 7 of 9
Victoria.Studley
Hi @cbohannon,
I'm just checking in to see if you need more help with this. I couldn't see the screenshot that you posted showing exactly what the problem is, but did the uninstall/reinstall of the program help you solve the issue?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Victoria Studley
Principal Experience Designer - Fusion Configurations
Join us in the Fusion Insider Program
Fusion Learn & Support | Fusion Documentation
Message 8 of 9
cbohannon
The uninstall / reinstall resolved my issue. Thanks for the check up!
Message 9 of 9
Victoria.Studley
Hi @cbohannon,
I'm glad to hear it. Thanks for following up!
Victoria Studley
