Right click command RELOAD, UNLOAD, DETACH, BIND xref asking to select object when object is already select
i have this drawing when opened and any xref inside it if you select the xref, then right click and use the xref related command. it ask you to select the object again. if i open more drawing this behavior carries on, including new drawing from template. If i don't open this drawing, then any other drawing is fine. i dealt with this behavior before and when you restart session it fixes it. However this file is persistent.
played with variable and all good. like pick first and anything selection related in the options. it is a civil 3d drawing so not sure that has anything to do with it. i didn't restart computer for a while but that shouldn't be it since it only get triggered with this particular drawing. 2019 format.
i attached it maybe someone can take a look why, just be careful don't open more files on top of it in case it infect other drawing. I worked long enough to see that happen before, open file infect other files with wrongful behavior.
try load any other cad as xref and see if you can replicate the problem.
Thank you!
Dell Precision 5530, Prism M320PU, C3D 14/17/19
