Anuncios
ricoh driver problem
No aplicable
Anyone know if a Ricoh MP 4055 will work with autocad? Installed the driver for the ricoh printer and whenever Autocad is started will not load until the print spooler is turned off or the print driver uninstalled.
thanks
Responder
3.133 Vistas
21 Respuestas
Respuestas (21)
No aplicable
I believe they are still having issues and I'm going to have to travel to where she is to look at the configurations. One question I have is, can pc3 files cause conflicts and startup to fail? Can I edit those files and see if there is an old reference to the old printer or something causing a problem to load if I can't find anything else wrong in other locations?
0 Me gusta
john.vellek
Hi @Anonymous,
You can edit a PC3 just by double-clicking on it.  The customer indicated to me that this is happening on non-AutoCAD workstations too though so I am not sure that will do much good.
If this were my environment, I would remove all custom content from AutoCAD, Reset Settings to Default and then see if you can launch and print to the System driver (not a PC3).
John Vellek
0 Me gusta
