Anuncios
Ribbon Tab Will Not Appear
No aplicable
I am so frustrated that I can't get this additional Electrical ribbon tab to appear. I've posted some pictures of where I'm at. Picture 1 you can see I added it to my workspace in the cui directly under the All You Could Ever Need tab. However, on picture 2 you can see that the All You Could Ever Need tab is appears in the ribbon but the Electrical tab is no where to be found. On picture 3 you can see that the Electrical tab is not being hidden. It's like it doesn't exist. What do I do now?
0 Me gusta
Responder
516 Vistas
7 Respuestas
Respuestas (7)
john.vellek
Good morning schweitzernic,
 It looks like you need to drag your Electrical panel into the All You Could Ever Need folder.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
0 Me gusta
No aplicable
I would like them to be two separate tabs though.
0 Me gusta
john.vellek
Hi schweitzernic,
Let's try this since I cannot duplicate the error on my side.
Try following the steps I went through: (AutoCAD 2016)
CUI
Rt-click Workspace>New Workspace>Test
Select Test Workspace (set it to current)
Then move down the tree and go to Ribbon>Tabs
Rt-Click>New Tab>Test1
Rt-Click>New Tab>Test2
OK your changes. Does the new workspace appear? And, do both Tabs show up?
If so, you can simply rename and then add panels as required.
John Vellek
0 Me gusta
pendean
Community Legend
Community Legend
Test; remove the other Tabs and only have ELECTRICAL, does it show up?
Even after yo select another workspace then come back to this workspace?
0 Me gusta
No aplicable
@john.vellek wrote:
Hi schweitzernic,
CUI
Tried this and the Test workspace is active but the ribbon says "The Ribbon does not have any tabs or panels currently loaded."
0 Me gusta
john.vellek
Hi schweitzernic,
This is unusual behavior!  I have attached an AKN Article that describes your symptom and possible fixes. Please take a look and let us know how you would like to proceed.
My gut tells me that you should do the Reset but it will obviously have the most impact on you. Please post your results.
John Vellek
0 Me gusta
john.vellek
I am checking back to see if my post helped you with your problem. Please add a post with your results so other Forum users can benefit.
John Vellek
0 Me gusta
