Revision Cloud Changing Arc Lengths in AutoCAD 2022
ndawsonmccann
ndawsonmccann
I just upgraded from AutoCAD 2020 to 2022 and right away I noticed that Revision Cloud Arc lengths are not uniform in size. Is there a way to have all arcs be the same size as they were in AutoCAD 2020 or earlier? I attached a sample drawing and an image, comparing the two.
Thanks!
Patchy
It controlled by Arc length settings.
With 2008 version, I can do both:
ndawsonmccann
I only see one Arc Length setting under REVCLOUD. I changed it to 0.1 and I style get the different revcloud sizes.
Patchy
See if this apply:
vasanth3H29R
Community Visitor
Community Visitor
Yep It's working man. Thank for the comments
Stephen_Weatherley
Community Visitor
Community Visitor
Thank you so much Patchy! If I wanted to draw garbage like the default brings up I would use crayons in microstation.
