Revcloud not fully functioning
rgarwood62DKH
rgarwood62DKH
Revcloud command only lets you select arc size. cannot draw rectangle, polygon, or select object. I suspect a support file is missing.
pendean
Community Legend
Community Legend
What does ABOUT command list as your AutoCAD version?
Which REVCLOUD command and options are shown in the commandline when you start it? Expand the commandline to show you 5-10 likes and see what is going on. Post a screenshot of it here if you'd like help deciphering it.
rgarwood62DKH
22.0.022.16 AutoCAD Map 3D 2019.0.1 Update
I always keep 5 lines on the command line.
Command:
Command:
Command: REVCLOUD
Arc length set at 10.000
       Arc length/<Pick cloud starting point>:
when using the RIBBON selecting Rectangular REVCLOUD
Command:
Command: _revcloud
Arc length/<Pick cloud starting point>: _R
Point or option keyword required.
pendean
Community Legend
Community Legend
Thanks for the commandline copy from MAP3D2019: the prompt is asking you to start drawing the cloud by clicking on screen and moving your cursor.
You either have a unique command in MAP3D (this is not the forum for that variant), or you have a customziation that is running instead. In plain AutoCAD (the topic of this forum) placing a period ahead of the command name will trigger the core command, that may work for you. Like this
.REVCLOUD
FYI the Map3D forum is over here https://forums.autodesk.com/t5/autocad-map-3d/ct-p/72
HTH
rgarwood62DKH
Thanks. This gives me new ideas to search for the cause of the problem. I will post on the MAP3D forum, but I don't think this is a MAP3D specific problem.
rgarwood62DKH
It was a customization lisp that was the problem. This group has been drafting since the dawn of time and had a lisp to add REVCLOUD before AutoCAD had it preinstalled.
