Requirements for autocuad
antoniostvrgs11
Community Visitor
antoniostvrgs11
Community Visitor
Community Visitor
Good afternoon, i am interesting in bought a Laptop thinkpad T460s
i5 - 6200
Intel Graphics 520 HD
8 gb ddr4
240 SSD
I want to know if the device can run autocad 2D and a light 3D.
0 Me gusta
Responder
1.705 Vistas
3 Respuestas
Respuestas (3)
BeKirra
Here is a starting point:
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/System-r...
A 16GB of rem or greater would be better.
HTH
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
0 Me gusta
-FDC-
It all depends on what you are planning to do with autocad.
For small projects this configuration will do.
If you want to do larger projects I would recommend a dedicated graphics card, the intel graphics is integrated in the processor.
The more you pay, the more you'll get.
Ideal would be:
I7 instead of I5
16gb instead of 8
Geforce or quadro instead of intel graphics
500 instead of 240 SSD
pendean
Community Legend
Community Legend
Basic AutoCAD system requirements for an average user:
An i5 or i7 processor running at 3GHZ or higher native clock speed.
8GB Ram
A video card other than a life-sucking Intel HD option with 2GB Ram or more.
If a laptop, 15" screen minimum size: if you want to use it with an external monitor (so you can get a smaller laptop screen), you need to make sure the external monitor can be run at HD display settings (not the low end 1024x768 common on cheap laptops).
A harddrive large enough to hold all of your files: 500GB is good, 1TB is better.
My personal 'upgraded' suggestions for 90% of users out there (you can always add more if you feel you can justify it):
Desktop: i7-7700 clocked up to 4.2Ghz, 16GB RAM (minimum), 512GB SSD (minimum), GTX1080 4GB or Quadro M2000 4GB (minimum)
Laptop: i7-6820HQ, 16GB RAM (minimum), 512GB SSD (minimum), Quadro M2000M 2GB or FirePro W5170M 2GB (minimum)
0 Me gusta
