Replacing some instances of a block used many times in the same drawing
ngancitano
Observer
ngancitano
Observer
Observer
So I've used the same block about 50 times in a drawing. I now have to replace about 20 of them with another block while leaving the other 30 untouched. I was wondering if there was a quick way to do this without deleting them all then placing them with the new block one at a time.
Maybe a way to rename the 20 blocks I have selected so I can then do just replace those all at once. I've read that there is a copy block definition command but I haven't been able to find it.
0 Me gusta
Responder
Soluciones aceptadas (2)
1.017 Vistas
4 Respuestas
Respuestas (4)
sthompson1021
ВeekeeCZ
Solución aceptada
It seems to be simple and quick...
just those 20 block copy into another drawing... rename.. change/replace (blockreplace)
while that in the first drawing erase the previous selection
and paste the new-ones back...
Kent1Cooper
Solución aceptada
Here's what I use -- BlockReplace.lsp with its BRS and BRA commands.  You would want BRS, which stands for Block Replace: Selected [as opposed to All].  See comments at the top of the file.
Kent Cooper, AIA
ngancitano
Observer
Observer
Thanks! This is the solution I ended up using. You saved me a ton of time this Monday morning.
0 Me gusta
