Repeat Last Command Problem
jmartt
jmartt
Yesterday, for unknown reasons, I noticed that my Repeat Last Command was kinda broke.
(2016 Civil 3D but this exhibits same behavior in the "as AutoCAD" program that comes with it.)
For some commands, not all, but including Move, Rotate, Copy and Scale, if I Repeat Last Command, either with right-clicking or with space bar, it gives me Select instead of the command. And just Select; like it doesn't proceed with the Move command, for example, after I select something.
I didn't change my right-click customization. Pickfirst is set to 1.
 I'm not at all sure this started happening yesterday. I hope it hasn't always been like this and I just now found it annoying(?)
Thanks.
rkmcswain
jmartt
This must be the problem. But I don't know why it is happening. Simple rotate command followed by an attempt to repeat last command.
Command: _rotate
Current positive angle in UCS:  ANGDIR=counterclockwise  ANGBASE=0.0000
Select objects: 1 found
Select objects:
Specify base point:
Specify rotation angle or [Copy/Reference] <28.9865>:
Command: _select
Select objects: !previousSelection
<Selection set: affa>
1 found
Select objects:
Command: *Cancel*
;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;this is where I pressed space bar for repeat last command
Command:  SELECT
Select objects: *Cancel*
jmartt
Well folks, it was definitely this diLeader app:
file:///C:/Users/sea/AppData/Roaming/Autodesk/ApplicationPlugins/DuctiSoft_DiLeader.bundle/Contents/help.htm#inunininfo
It never really installed so as to populate my Add-ins ribbon although it showed-up in my Exchange App Manager. But the Uninstall text was grayed-out. I had to uninstall it using Windows.
After I uninstalled, the next drawing I started behaved normally as far as the Repeat Last Command was concerned.
Hope this helps someone.
