rendering problem in AutoCAD
shallowhead
shallowhead
Hi, when using the render command, it only renders front view only. any ideas as to why I cannot render my whole dwg? attached is the simple 3d dwg. The left wall wont render??
@shallowhead
john.vellek has edited your subject line for clarity: rendering problen
Replies (15)
john.vellek
HI @shallowhead,
The only object that has 3D Face , surface, mesh or solid is that face and the top perimeter trim piece.
Were you expecting something different? You need to make the other sides of the shed have "faces" of some sort.  In this image I used Surfaces.
John Vellek
shallowhead
 Thanks for the reply John.
This shed is far from complete but I'm sure that the left wall and the top 4 rafters are also a 3dface. Other walls I haven't finished yet.
But here's my render attached. It wont render the left wall, or the other two rafters (left and right)??
confused.....
john.vellek
HI @shallowhead,
This is too dark to see anything. Turn on the Sun or other illumination to see if that helps.
Which version of AutoCAD are you using?
John Vellek
shallowhead
Im using autocad map 2010. Can you see the two rafters that did render in the bmp?
I will look for some illumination ....
john.vellek
Hi @shallowhead,
AutoCAD Map 2010 is pretty old and different than anything I have installed.
I can tell you however, in AutoCAD 2019, I can turn on shadows and the sun and when I render I see the wall and rafters.
John Vellek
shallowhead
OK...I'll try some other things, thanks again for your help...
shallowhead
okay I'll try some other things thanks again for your help.
KT
ChicagoLooper
Your must have a solid or surface model and not just lines in order to render. You can easily distinguish between solids and mere lines without going throgh the render process by changing the Visual Style in modelspace.
In upper left, change from 2D Wireframe, the default, to either conceptual or realistic so you can see what's actually a 3D object and capable of being rendered. As you can see, only one wall and top-of-walls are 3D objects and capable of being rendered.
Switch to 'Conceptual' or 'Realistic.'Switch to 'Conceptual' or 'Realistic.'
Chicagolooper
shallowhead
Thanks for the reply C. Looper.
This shed is far from complete but I'm sure that the left wall and the top 4 rafters are also 3dfaces. Other walls I haven't finished yet. I DO Realize I need 3d faces to render or shade, But here's my render attached (.bmp file). It wont render the left wall, or the other two rafters (left and right) and they are 3dfaces??
shallowhead
Here's a revised file but still cant render all the walls for some reason (render 2.bmp)......any ideas??
john.vellek
Hi @shallowhead,
It seems to work fine on my end when I turn on the Sky and illumination. Your image shows that you need to adjust some lighting.
John Vellek
ChicagoLooper
Excellent idea. I was thinking to lighten or brighten the materials/colors used in the rendering, but I think @john.vellek has a better solution by adding lighting.
Chicagolooper
john.vellek
Hi @shallowhead,
Have you tried adding some lights to your model?  I am hoping that is all that you are missing to get this working.
John Vellek
shallowhead
OK, yes  I did add some lighting with better results.
Its been sometime that i did rendering...but I do remember before i could render without customized lighting. It was more or less a general lighting that must have been default perhaps.
Now i just need to place my point light in a better location, but proving a bit difficult....
john.vellek
Hi @shallowhead,
I am glad you are making some progress with the lighting.  I like to actually draw a line from the target to the plan location where I think I want my light(s). Then I change the Z value of the line to the height of the light  location.  Then, when I place my light I have a nice construction line to help.
John Vellek
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
