Anuncios
Rendered Lights Appear Spotty or Starry
No aplicable
     When I render any lights, they appear spotty with a Lights & Material Render Accuracy of Draft and starry when I change the setting the High.  Please see the attached images.  The plane is teak, the solid sphere is paint, and the lit globe is frosted glass.  I played around with lighting settings, changing materials, the shapes of lights, using different kinds of lights (including self-illumination), etc.
     I've never had this problem before 2018.  When I render the same scene in AutoCAD 2018 on my laptop, it's fine.
Thank you,
Jarrod
I also have the recommended driver version (375.86) as found on Autodesk's certified hardware page:
Card name: NVIDIA Quadro K4200
Driver version: 21.21.13.7586
Tuning Date: 1/31/2018
Virtual device: Dx11 (Hardware)
                The card and driver meets the recommended requirement.
Display Adapters:
 NVIDIA Quadro K4200(Primary)
Certification:
 Hardware Available     True
 Hardware Recommended   True
 Status                 2
 Hardware ID            2
 Hardware Feature Level 50
 Software Feature Level 50
General Options:
 Adaptive Degradation           True
 Discard Backfaces              True
 Dynamic Tessellation           True
 Generate Vertex Normals        False
 Handedness                     Right
 Maximum LODs                   6
 Redraw on Window Expose        True
 Surface Tessellation Tolerance 92
 Transparency                   MediumQuality
Additional System Information:
 ComputerSystem
  Manufacturer        LENOVO
  Model               30AHCTO1WW
  NumberOfProcessors  1
  TotalPhysicalMemory xxx-xxxxxxxx
 Processor
  MaxClockSpeed             3601
  Name                      Intel(R) Xeon(R) CPU E3-1271 v3 @ 3.60GHz
  NumberOfCores             4
  NumberOfLogicalProcessors 8
  Revision                  15363
 OperatingSystem
  Name                    Microsoft Windows 10 Pro|C:\WINDOWS|\Device\Harddisk0\Partition4
  OSLanguage              1033
  ServicePackMajorVersion 0
  ServicePackMinorVersion 0
  TotalSwapSpaceSize
  TotalVirtualMemorySize  19189332
  Version                 10.0.16299
 DiskDrive
  Model SanDisk SD6SB1M256G1001
  Name  \\.\PHYSICALDRIVE0
  Size  256052966400
 DesktopMonitor
  MonitorManufacturer (Standard monitor types)
  MonitorType         Generic PnP Monitor
  Name                Generic PnP Monitor
  ScreenHeight
  ScreenWidth
 DisplayConfiguration
  DeviceName       NVIDIA Quadro K4200
  DisplayFrequency 60
  DriverVersion
  PelsHeight       768
  PelsWidth        1024
 VideoController
  AdapterDACType              Integrated RAMDAC
  AdapterRAM                  4293918720
  ConfigManagerErrorCode      0
  CurrentHorizontalResolution 1920
  CurrentVerticalResolution   1080
  DriverDate                  20161110000000.000000-000
  DriverVersion               21.21.13.7586
  InstalledDisplayDrivers     C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispwi.inf_amd64_ef4c14a7f979dba3\nvd3dumx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispwi.inf_amd64_ef4c14a7f979dba3\nvwgf2umx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispwi.inf_amd64_ef4c14a7f979dba3\nvwgf2umx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispwi.inf_amd64_ef4c14a7f979dba3\nvwgf2umx.dll
  Status                      OK
  TimeOfLastReset
  VideoArchitecture           5
  VideoModeDescription        1920 x 1080 x 4294967296 colors
Process Information:
 Loaded ARX and CRX Modules
  acapp.arx
  acapp.crx
  acautoloader.crx
  acautoloader.arx
  acexperience.arx
  acpublish.crx
  acpublish.arx
  AcPi.arx
  acjscorestub.crx
  acgsconfig.arx
  acgsconfig.crx
  acvmtools.crx
  vl.crx
  accloudconnect.crx
  acconnectwebservices.arx
  aclaunchnfw.arx
  acsign.arx
  acetutil.arx
  vl.arx
  acsceneui.arx
  AcCamera.arx
  acsceneui.crx
  acdim.arx
  acdim.crx
  AcFdUi.arx
  acvmtools.arx
  acopmext.arx
  acopm.arx
  acobjclassimp.arx
  AcOcSchemaUtil.arx
  AcPEXCtl.arx
  actp.arx
Effects:
 ACAD_LineSmoothing      supported     turned on
 ACAD_PerPixelLighting   supported     turned on
 ACAD_AdvancedMaterial   supported     turned on
 ACAD_FullShadows        supported     turned on
 ACAD_TextureCompression supported     turned off
 ACAD_HQGeom             supported     turned on
 ACAD_GlowHighlighting   supported     turned on
 ACAD_Dx11               supported     turned on
0 Me gusta
Responder
Soluciones aceptadas (1)
461 Vistas
2 Respuestas
Respuestas (2)
TheCADnoob
Give this Autodesk Knowledge Network article a read and see if it helps
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/High-q...
CADnoob
0 Me gusta
No aplicable
Solución aceptada
Thank you for your response.  I increased the rendering levels, but it didn't improve the lighting situation.
I upgraded the other computer to Windows 10 1709 Fall Creators Update and now it is causing the same problem.  I'm going to chalk it up to the Windows update that Autodesk said is causing problems.
0 Me gusta
