Render Setting
Render Setting
siad_vidal
Render Setting
siad_vidal
There is i can set for render engine in AutoCAD 3D modelling? like CPU or GPU, or there is automatically choosed?
Please tell me up 🙂
Thank you
paullimapa
Alfred.NESWADBA
Well, what's the real question? Searching for a setting for use of command _RENDER or while modelling, which are different...
To assign CPU or GPU for command _RENDER is not possible any more, it was a while ago, but not any more. It uses multi-cores of your CPU, but not the GPU.
To make more use of GPU while modelling you should set your drawing (your current viewport) to a visual style other than "2D Wireframe" ... that gives the graphic card more work for getting the display refreshed while modelling, zoom/pan/orbit ...
HTH, - alfred -
Alfred NESWADBA
(not an Autodesk consultant)
siad_vidal
Oh thank's, that was helpfull tip. i thought there some setting to choose the engine render like 3D Blender 🙂
siad_vidal
I mean, can i switch the CPU to GPU engine for boosting my image result from rendering process on AutoCAD?
Alfred.NESWADBA
As I wrote, you can not configure the usage of CPU vs. GPU for command _RENDER.
- alfred -
Alfred NESWADBA
