Render problem
Render problem
Beka_Tchigladze
Advisor Advisor
Message 1 of 9
Render problem
Beka_Tchigladze
Hello I have such kind of problem, my autocad works good, but when i try to render there is black window, it is only when i try to render light, when i donot use light in my model space render works correctly but, when I use light, render window is black please help me to solve this problem there is som of screen shots
as you see there is light in my model space
and after render my render window is black there is no nothing
at last when i delete light from my model space render works correctly
how can i solve?????
Beka Tchigladze
Road/Highway Technical Designer
AEC Collection/C3D 2025
WIN 11 64 PRO
Predator Helios 18, Intel Core i9 14900HX, 32 GB
NVIDIA RTX 4080, 12 GB
YouTube--->Linkedin
Replies (8)
Message 2 of 9
Alfred.NESWADBA
can you please upload the DWG (including the light which seems to work incorrect) + let us know your AutoCAD release (as 2016 has another renderer compared to the releases before).
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 9
Beka_Tchigladze
thank you for your answer, I have Autocad 2016 there is my DWG I have Civil 3D 2016 buT I have tried it in standart Autocad 2016 but there was same result
Beka Tchigladze
WIN 11 64 PRO
YouTube--->Linkedin
Message 4 of 9
Alfred.NESWADBA
sorry, no drawing attached.
[EDIT] now it's there ,;) [/EDIT]
- alfred -
Alfred NESWADBA
Message 5 of 9
Beka_Tchigladze
sorry there is
Beka Tchigladze
WIN 11 64 PRO
YouTube--->Linkedin
Message 6 of 9
Alfred.NESWADBA
difficult now to see your issues from your top screenshots with a different drawing, can you please make the screenshots with this drawing you sent now?
What might be important for you is the message (at least I get) when starting rendering:
That might also be an answer for rendering issues within your project.
At least you drawing rendered by AutoCAD 2016 on my system gives that result, nothing black here (as mentioned in the original post).
- alfred -
Alfred NESWADBA
Message 7 of 9
Beka_Tchigladze
there is my screenshots  there you cen see spotlight on the screenshot Capture12.JPG
Capture.JPGCapture13.JPGrender window is already black if i turn off ech of light in my drawind render works corrextly but when i want to render light effect it seem like this
there is my drawing with light in the attachments
Beka Tchigladze
WIN 11 64 PRO
YouTube--->Linkedin
Message 8 of 9
Alfred.NESWADBA
sorry for my late response (on limited time now).
You've set the units to "Meter" in the drawing, so the spot is 1600m above the floor level ==> no light will be able to show a luminance at this distance (besides of laser).
Change the units to "Millimeter" and you will see something like that:
- alfred -
Alfred NESWADBA
Message 9 of 9
Beka_Tchigladze
thank you very much 🙂
Beka Tchigladze
WIN 11 64 PRO
YouTube--->Linkedin
