Removing all Xrefs
mliuMGKLT
Removing all Xrefs
mliuMGKLT
I am trying to remove all xrefs from my file. I setup a shortcut so that when I press it, it runs the following command
("-xref" "deatch" "*")
but when it runs it tells me there is "no matching xref names found" and doesn't remove any of the xrefs. Am I doing something wrong? Any help appreciated.
0 Me gusta
Responder
241 Vistas
2 Respuestas
Respuestas (2)
dmfrazier
I'm surprised the code works at all. (Perhaps the typo doesn't exist in what you're actually running.)
In any case, when I run it (corrected), I get this error: ; error: bad function: "-xref".
If I use the command function instead (command "-xref" "detach" "*") on a DWG that has no Xref, I get the "no matching Xref.." response.
However, if I run it on a DWG that has an attached Xref, it works (returns "nil" and detaches the Xref).
0 Me gusta
mliuMGKLT
Sorry, was typing fast and accidentally made a typo. I figured out my problem. Command was running successfully, like you said. I just didn't realize it was since it wasn't removing everything. The stuff left weren't .dwg files so the command wasn't removing them. Have to find another method for autocad to remove it.
0 Me gusta
