Remove Student Version Plot Stamp Warning
chadwickt
Message 1 of 15
chadwickt
Is it possible to disable the warning for the Student Version plot stamp? To be clear, I am not wanting to get rid of the plot stamp itself, just the dialog box that warns that it is there. I teach an online class where hundreds of AutoCAD files are submitted to me throughout the semester. It is getting a little tiresome to have to click "Open" at the warning screen each time. Of course, "Cancel" is the default option so I cannot just press Enter, though I can arrow over then press Enter.
If it is not possible, I am not going to complain. I think it is wonderful that Autodesk makes the software available to students. They could not take my class without it. While I can live with it, it would sure be nice to eliminate some clicks 🙂
Replies (14)
Message 2 of 15
cadffm
I am not aware of any possibility from the software, but who cares (which I can understand if you have to access many files per day),
then install a customizable pop-up handler which always clicks "Open" in the window.
There are various programs (internet search).
So you would see a maximum flicker and would have basically reached the goal.
Sebastian
Message 3 of 15
chadwickt
Thank you for the idea. I think I have found a workflow that works. I have to press Enter to confirm that I want to open the file, then Enter again to confirm that I want to open it read only (I am opening directly from the Web), and now I am just tapping the arrow key then pressing Enter to get past the warning. I have done it dozens of times already so I am already getting used to it.
Thanks!
Message 4 of 15
GrantsPirate
Open with R2018 instead of R2019.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
Message 5 of 15
dgorsman
If you have a multi-button mouse, check to see if you can program that key sequence in and assign to one of the extra buttons.  That can save you a few extra steps.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
Message 6 of 15
gotphish001
You could open the drawings with autocads trueview. It's opening drawing as read only so I don't think you would get the pop up at all. I haven't tested it though. Easy enough to install it along side autocad and have both. It's also free too with no need for a student version.
Nick DiPietro
Cad Manager/Monkey
Message 7 of 15
cadffm
It would be right for TV version between 2014-2018, but not because of read-only, because you can plot from TV.
It is because these versions ignore the edu flag.
Sebastian
Message 8 of 15
chadwickt
It looks like the short answer is that I am stuck with the dialog box. Thank you for the suggestions for work arounds. I am getting used to just arrowing over and pressing Enter, so I will stick with that.
Message 9 of 15
Same question. help if anybody can...
Message 10 of 15
cadffm
Message 11 of 15
chadwickt
What exactly do you mean by "nobody has anything to remove"?
Message 12 of 15
pendean
Community Legend
Community Legend
See the link, you already know the answer, nothing has changed, you stated as much in your earlier reply that is tagged as a solution to this thread, @cadffm is simply confirming it.
Message 13 of 15
chadwickt
I agree that nothing has changed. I was surprised to see this pop back up. However, "nothing has changed" is quite different than "nobody has anything to remove", hence my question.
Message 14 of 15
pendean
Community Legend
Community Legend
Lots of folks stumble into older posts through google searches and reply to them without paying attention or hoping things have changed, it happens all the time.
Posts are never locked.
Message 15 of 15
chadwickt
That was my next question. I didn't realize posts were never locked. Thanks, and have a great day!
