In some cases, if I put the pointer to the grip and stay for a while, a new window pops up and I could select remove. In some cases, it doesn't show up. How could I let it show up? thanks
Hello
If you are running ACAD 2018, maybe you will appreciate this Hotfix !
Regards, Patrice
Patrice BRAUD
If it happens only sometimes, or at only some but not all vertices on the same Polyline, a cause can be that you have coincident vertices, i.e. two [or more!] vertices at the same location, in which case it won't give you those options. To check, pick the Polyline, and in the Properties box, pick in the "Current Vertex" slot, and use the up/down arrows to move the big-X marker around. If it doesn't move at some vertex at a pick on the up/down arrow, but the vertex number changes, that means there are coincident vertices. If that's the problem, you can eliminate the extra one(s) with PEDIT in the Edit-vertex option, using the Straighten option [read about it in Help]. And I would bet there are routines on these Forums that can find and eliminate them.
Sebastian
Hello @Kent1Cooper , @cadffm
This "strange graphic" 2018 Bug is not specific to PLines !
Please see this French Video with an Arc ...
Regards, Patrice
Patrice BRAUD
