Remove hatch from internal island
kubastan89
Message 1 of 9
kubastan89
Can you tell my how I can remove the hatch from this internal square from the drawing?
I know that I can create a hatch that will isolate internal island but what if I would like to remove some island from the existing hatch ?
Replies (8)
Message 2 of 9
beyoungjr
Click on your Hatch to bring up the Hatch ribbon.  Click on the icon "Select" in the first Panel.  Use a window to select only your internal square/rectangle. Hit Enter.   Click "Close Hatch Editor".
Done
Blaine
Blaine Young
Senior Engineering Technician, US Army
Message 3 of 9
gotphish001
Click on the hatch. In the hatch ribbon click off the associative button, then on the left off the ribbon pick the select command. Click on the small square polyline that you want to remove the hatch in, hit enter. That should remove it.
Nick DiPietro
Cad Manager/Monkey
Message 4 of 9
gotphish001
Blyoung is correct. You don't need to uncheck the associative box. I thought you did as the first time it didn't work unless I did. I must have missed clicked something as it worked in two subsequent tests.
Nick DiPietro
Cad Manager/Monkey
Message 5 of 9
Vinayv4v
You can use the remove Boundary option in hatchedit.
Cheers,
Vinay Vijayakumaran
Message 6 of 9
HI
To remove inside hatch, you can do WIPOUT (WIP) [FOR AFTER HATCH CREATION].
You can use SELECT OBJECT OPTION and PICK INTERNAL POINT option while in hatch creation.
You can also view YouTube video by below link [ ENGLISH VERSION }
https://www.youtube.com/watch?v=di_3QERfkDM&feature=youtu.be
Message 7 of 9
Thank you. I tried every single thing with no luck and finally I could do it in a simple step.
Message 8 of 9
In AutoCAD 2019 - In the model space
After you have created polylines around the areas that you want to contain a hatch and not contain hatch
  • Click on the hatch icon in the Draw ribbon
  • Adjust the settings on the Pattern and Properties panel to your preferences
  • Click Select in the Boundaries panel and select the outer shape
  • Click Close Hatch Creation
  • Type WIPEOUT in the command line and click on Polyline
  • Select the polyline that you want to erase the hatch from
  • Click Enter
Message 9 of 9
Thank you, you are a saviour!
