Remove Frame (Border) for a Single Raster Image Only
I am in AutoCAD 2016 on Windows 7.
Is there a way to turn off the frame for a single raster image only?  I know of the IMAGEFRAME command which can toggle on/off the image frame for all images.  But was wondering if there is a way to turn off the frame for a single raster image only, while leaving the frame on for all the other raster images.
Thank you,
Michael Murrin
vinodkl
IMAGEFRAME controls the frame of all the raster image in the drawing. If in case you want to hide the frame of single raster image I would suggest you to insert that image as OLE and set OLEFRAME to "0".
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
imadHabash
HI,
>> .....But was wondering if there is a way to turn off the frame for a single raster image only
it's a global setting , showing and hiding image boundaries affects all images attached to your drawing.
Imad Habash
Alfred.NESWADBA
My answer is the same, no, you can't.
But one step more ... why do you need that? If we know the background info maybe we have some ideas for workarounds.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Kent1Cooper
Just a thought [don't have AutoCAD running] -- If you put an Image on a non-plotting Layer, does the image itself print but the frame not?  [That's the way paper-space Viewports work -- their boundaries don't, but you still get what shows through them.]  If so, leave the frames on, and make a non-plotting Layer to put that one on.
Alternative tedious workaround:  turn frames off, and draw Polylines around the boundaries of all but that one.
Kent Cooper, AIA
