Remove a large hatch unstable file
No aplicable
Hi all I have accidentally hatched a very large area in my file and have managed to hide the layer (Large area 100s of acres).However every time I unhide and try to select it the file hangs. Can you please advise if there is a way to delete the hatch only. I need to retain the layer as there is other content.
thanks in advance
0 Me gusta
Responder
1.380 Vistas
9 Respuestas
Respuestas (9)
vinodkl
Use the command "QSELECT" to select the hatch and delete it based on the different properties of the hatch.
P.S if you have the hatch in a particular layer and you are not able to turn it on or thaw that layer then use the command "LAYDEL" and then select "NAME" from the commandline and specify the layer name to delete that layer. Note: make sure you don't have any other elements in that layer apart from the hatch.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
imadHabash
this hanging NOT because it's for a big area , there is something else . before you delete it , let's try :
  • Make sure that the Properties palette is not open before you select the hatch object , any changes ?
  • check and follow here for why AutoCAD freeze when select a hatch . >> Click <<
Hope it's help ..
Imad Habash
0 Me gusta
pendean
Community Legend
Community Legend
0 Me gusta
No aplicable
Hi thanks for the responses. Unfortunately the file hangs after selecting the hatch and then I’m forced to shutdown the program every time. No other issues with the file. I have had to redo the drawing sourcing old information. Thanks for your help.
Thomas_Stuehle
Hello @Anonymous
Thanks for the update.
I was wondering if WBLOCK, followed by the setting "Delete from drawing" and an object selection at the end also lets the application freeze. If not, you could use the WBLOCK function to delete the hatch.
Best regards,
Thomas
Your question got successfully answered? Then just click on the 'Mark as solution' button.
Thomas Stühle
Technical Support Specialist
0 Me gusta
nbennett
I don't know if you ever resolved this issue, I also ran into the same thing.  Large hatch being selected would freeze AutoCAD and ultimately I would have to end task to get it bake.
Solution for me was to freeze all other layers  then enter the erase command but instead of selecting the object just type in ALL on the command line and it erased it with no issues. hope this will help you and others out.
0 Me gusta
ВeekeeCZ
Try to turn off GRIPS (sysvar) before you select it.
Also hiding the Properties Palette helps.
And if you often work with large HATCHs, I would unassign Hatch Modify Context Ribbon in the CUI (All properties are available in the Prop. Palette too).
0 Me gusta
Kent1Cooper
@nbennett wrote:
....  Large hatch being selected would freeze AutoCAD ....
It could be that it's the work of highlighting it that causes the trouble, and all you need to do is set the HIGHLIGHT System Variable to zero [and back to 1 afterwards].
Kent Cooper, AIA
0 Me gusta
pendean
Community Legend
Community Legend
Have you seen this from Autodesk on the topic https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/AutoCAD-freezes-wh...
0 Me gusta
