Reflection Map in AutoCAD 2014
Can I add reflection (environment) maps to materials? It used to be there in AutoCAD 2009 Material Editor but somehow can't find it in AutoCAD 2014.
Please assist.
Fahim.
Alfred.NESWADBA
sorry to say, you are right, I don't find a material type where you can assign a reflection map.
Even worse: when you have an old drawing that contains such a material it is converted in the wrong way and the image is then used as "reflectivity map" which is indeed something very different.
Sorry not to help, open your subscription center and place that as defect as settings in old drawings are lost (data loss is quite critical in my undertanding).
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Thanks for confirming that, Alfred.
