Ref not lining up with my page
Hello, on my page the ref lines up perfectly but when I plot it is missing the right & top line. When my colleague uses the same drawing and plots from her computer it lines up perfectly. I have checked the base and they are all set to o.
Vinayv4v
Hi Sarah,
Can you please attach the drawing?
Cheers,
Vinay Vijayakumaran
imadHabash
HI,
I suggest to do some calibration for printable area (see below image).select your printer then Properties then Modify standard paper then select the paper that you choose for print then press Modify then you can modify Top,Bottom,Left and right options.
Imad Habash
john.vellek
Hi @Anonymous,
I suggest that you copy the PC3 and associated PMP file from your coworkers computer to your own. This should correct the margin and offset issue you are seeing. You can also do this manually as suggested by @imadHabash
John Vellek
john.vellek
Hi @Anonymous,
I am checking back to see if my post or Imad's helped you with your problem. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
Hello - thank you for the suggestion. I mostly export as PDF rather than print so if I change the setting you have suggested will it work for PDF as well as the printer?
john.vellek
Hi @Anonymous,
Every printer driver includes hardclip limits (margins). So, I suggest you create a PC3 file each different type of print job you use.
Here is a post from a while back that might help you create your custom PC3 files.
John Vellek
