RED DOT NEXT TO CURSOR
Message 1 of 13
Can anyone tell me why this re dot has shown up next to my cursor.  I can't seem to figure it out, and it really bugs my supervisor!  See attached photo.
thanks
Replies (12)
Message 2 of 13
tcorey
Do you have a screen-recording software that might have added that?
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 3 of 13
mathewkol
Or AutoCAD's action recorder. Can we assume you have restarted? Does this happen after a restart?
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
Message 4 of 13
After restart it went away, yes.  It was weird because I saw it happen on two different machines within an hour yesterday.  I clicked on the record function within autocad and yep,  that exact same red bubble came up. So I suppose that funtion was accidentally triggered. By two different people on two different machines on the same map! How do you accidentally type _ASTRECORD .....weird!
Thanks for the replies
Message 5 of 13
JessicaPalmer
The command can also be started on Manage tab, Record/Stop.
Jessica Palmer
Message 6 of 13
The command was initiated by ARR, which is extremely close to a command that I added with a lisp file. It is turned off from the manage menu.
Message 7 of 13
If you type ARR   (intending to use array tool),  it comes first the command ACTRECORD. That's way the red dot apears next to the cursor. Cause it starts recording 😉
Message 8 of 13
Right Click.. Action Recorder (Stop) 🙂 good luck
Check attachment fyr
Message 9 of 13
Daniel.Lita
Type "ACTSTOP" if you can't find Recorder/Stop in right click menu.
Love & light to everyone.
Message 10 of 13
How to remove the red dot next to cursor?
Message 11 of 13
its recording you can stop it by right click and stop recording or  just type ACTSTOP in command line and enter.
Message 12 of 13
mchasenCADTechv12
I was using ARRAY and mistyped, apparently.
Thank you for posting this solution.
Message 13 of 13
cadFXH9K
Community Visitor
Community Visitor
Bingo!   Thank for sharing how to remove the red dot.   ACTSTOP
