Rectangles with Extension Snap
atg13pmb
Observer Observer
atg13pmb
Observer
Observer
Hi there
I'm trying to get the "extension" dimension to be the default for the Rectangle command.
So, for example when I draw a Rectangle, after selecting the base point, I want to be able to enter a dimension FROM an extension point. Like drawing a 600mm cupboard "extending" from a wall.
Image below shows which dimension prompt I would like to be the default selected.Untitled.png
I use AutoCAD 2022. Used to be able to do this on 2018, not sure if the option has been nuked.
Thank you very much
imadHabash
EXTension is one of object snap modes. You can by OSNAP command get snap modes and select them as needed.
Imad Habash
atg13pmb
Observer
Observer
I have the Extension snap and OSNAPs turned on
I've also tried adjusting the Dynamic Input settings, but the changes only seem to apply to lines.
Rectangles are the only shape that do not default to the Extension snap.
atg13pmb
Observer
Observer
Would "exporting" settings from another PC be a good idea?
