rectangle behaviour
rectangle behaviour
nicolas.guyader
rectangle behaviour
nicolas.guyader
I turned on autocad draw a rectangle on a project and it comes up like on the picture i never seen this before and i dont know what its called and how i can turn it off i use autocad 2014 Screen Shot 2016-04-07 at 13.59.22.pngon mac
You can use delete constrains or hide all from Parametric tab.
massimo.corradi
I believe the mac shortcut for this is Shift-Cmd-I, else you can switch parametric autoconstrain off by setting CONSTRAINTINFER to 0.
Best you delete first the ones you already generated since else they will be copied. (DELCONSTRAINT in case you haven't found the parametric tools yet)
nicolas.guyader
It worked like a charm. I didn t know what constrain were and it turned on by itself.
Autocad is great but there is so much i need to learn thank you guys for helping me in the process
