Anuncios
Recovering drawing file fail (not possible to open in AutoCAD)
tesfaye_kebede
tesfaye_kebede
Hei Everyone,
One of our customer has get a crash in AutoCAD and tries to recover the file and not possible to recover.
I have tried all the step defined in the Autodesk Knolwedge point to get fix this problem (like using the backup file, using insert etc..) , however not possible to fix.
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Recove...
Even renaming the *.bak file is also corrupted.
Is there any other way to solve this issue?  Attached the file.
Regards
Tesfaye H/G Kebede
Trimble Civil Engineering and Construction
0 Me gusta
Responder
387 Vistas
6 Respuestas
Respuestas (6)
jayhar
Hi @tesfaye_kebede
Did you try RECOVERALL comment ???
or rename .bak to dwg try it
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly. If your issue persists,
Please give me a bit more detail on this issue so we can continue to work towards getting this solved.
Revit Architecture Certified Professional
Thanks You
JAYHAR.M.J
Team Leader
Helpful Links: Prepare your computer for download |  Autodesk Virtual Agent | Clean Uninstall | AutoCAD randomly crashes or freezes
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
0 Me gusta
tesfaye_kebede
Thank you, All you explained above is well defeined in the link and I tested and used all step but not working.
Recover
Recover all
Rename *.bak file
etc...
pendean
Community Legend
Community Legend
No 3rd party software I have will open your DWG file, neither will any website viewer I tried.
0 Me gusta
jayhar
Hi, @tesfaye_kebede
I recommend turning on Autosave and setting the increment to 1 minutes. SAVEFILEPATH to be set in local drive create new folder name as Autosave. This is for future work.
Always keep a backup in a different location (not the same drive)
Install latest updates and service packs from autodesk.
recovering a drawing in a higher version of AutoCAD
No use you upoad .dwg here, because backup file saved in another system.
drawingrecovery is maximum
Thanks You
JAYHAR.M.J
Team Leader
0 Me gusta
tesfaye_kebede
Thank you for the good suggestion.
The customer works in a company which they have a backup system in a server.
They have a good routine as you explained but this happen sometimes.
Making a new drawing will not be 100% same as the one you made before.
So the only solution is to draw everything again?
Tesfaye K//
pendean
Community Legend
Community Legend
If the client has such robust and regular backups, why don't they retrieve them so at least not everything in the drawing has to be redrawn?
AUTOSAVE set to 10-minutes is more than adequate, 1-minute is mindlessly excessive.
0 Me gusta
