Hi and Welcome to AutoCAD Forum,
>> All that remain are the .bak file, which is a couple of hours out of date, <<
is that mean that you're working many hours without saving ???!!!!
>> ... and some temparary save files with extension .ac$. <<
By default, temporary files have an .ac$ extension. These files contain information that is used by various AutoCAD commands, such as UNDO, and do not contain any drawing data that can be recovered. They should only exist during an AutoCAD session but may be left behind if AutoCAD crashes or is abnormally terminated.
>> I know you can easily restore an automatic save .sv$ file. <<
Automatic saves are only done if a drawing has been modified after the last save. QSAVE, SAVE, and SAVEAS will delete the current .sv$ file and halt the automatic save timer until an edit is made to the drawing. If AutoCAD crashes or is otherwise abnormally terminated during a session, you can recover data saved in .sv$ files by locating the autosave file, renaming the .sv$ extension to dwg and then opening that file in AutoCAD. The autosave file will contain all drawing information as of the last time autosave ran. When AutoCAD closes normally, .sv$ files are deleted.
Note: Disabling automatic save ( OPTIONS >> Open and Save tab ) prevents AutoCAD from automatically creating sv$ files while you work. In the event of a crash, there will be no interim files to use for data recovery.
Imad Habash
