search on the .BAK file ( if exist ) and rename the extension to .DWG .
Imad Habash
That sucks. Did you check for a .bak file?
If you have not done to many file writes on your harddisk you might try undelete tools that exist in www (>>>click<<<, but take care, not all freeware tools are working well).
In case this fails too and the BAK file does not exist too, then restore the file from your latest backup.
- alfred -
Do you have a backup? If not, you may need some third-party tools to get them back. I think you can use the Bitwar Data Recovery, I have used this software to recover my permanently deleted files, this software is good to use, you can just have a try, hope it can help you anyway.
