REC command problem
REC command problem
Message 1 of 8
REC command problem
dear all
i want some help .
when i want to use REC shortcut it give me thet to select horizontal/vertical dimension .
so  how to change drawing type in REC command from select horizontal/vertical dimension to choose first/other corner
thank alot
jaweed alnazer
jaweed_1992@hotmail.com
Replies (7)
Message 2 of 8
rkmcswain
What actual command is REC calling for you?
Straight OOTB, REC is defined in the PGP file as a shortcut for the RECTANG command, which does not have a "select horizontal/vertical dimension" prompt.
Maybe your REC is a custom command. What happens if you type in .RECTANG (note the leading period)?
R.K. McSwain     | CADpanacea | on twitter
Message 3 of 8
Thank you for your replay
 When I complete the whole of the word "RECTANG" it asks me to choose the first /other corner <that’s what I want>
But when use the shortcut REC
It asks me to choose the horizontal/vertical dimension to draw, tomorrow I’ll attach screen cast for the problem
Thank you
jaweed alnazer
Message 4 of 8
rkmcswain
As I said above "Maybe your REC is a custom command."
Who is the admin of your CAD system? Sounds like they have defined a command with the shortcut REC. Ask them.
Message 5 of 8
Thank you for your reply
Its my own PC
Maybe it is custom command but can I change it back
Message 6 of 8
pendean
Community Legend
Community Legend
Or it could be an add-on you have: REC for the rest of us is RECTANG command and nothing else.
Do this if you aren't sure, it should get rid of all non-AutoCAD content in your setup https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to...
Message 7 of 8
Thank you pendean
Still the Same problem 🙁
Message 8 of 8
rkmcswain
Create an ASCII file named "AcadDoc.lsp" and put it in the TOP path in your Support File Search Path.
Inside this file, put the following autolisp code.
(defun c:REC () (vl-cmdf "._rectang"))
Save the file.
Start a new drawing.
REC should work now.
