Anuncios
Raster Images publish black
No aplicable
I am working with raster, tiff, bmp images in model space and when I publish them the view ports is black and the balloons are missing.  I have tried multiple things and nothing works.  I have opened previous drawing with viewports and they work fine, but I can not find the one thing that has changed.
0 Me gusta
Responder
1.661 Vistas
12 Respuestas
Respuestas (12)
Alfred.NESWADBA
Which driver did you use for _PUBLISH?
What is meant by "balloons are missing"?
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2025
(not an Autodesk consultant)
0 Me gusta
No aplicable
I used File publish and the balloons are in the dwg but in the pdf they are in the black area, sorry they are there but can not see them
0 Me gusta
Alfred.NESWADBA
Can you please upload such a dwg-file so we know what type of geometry your balloons are (as AutoCAD does not have a "balloon" object).
Which driver did you use to publish to PDF?
- alfred -
Alfred NESWADBA
0 Me gusta
3wood
Does it embedded in a block? You can try explode the block to get normal print.
Refer to: https://sites.google.com/site/cadkits/autocad-faq/autocad-tips/image-prints-out-as-a-black-solid
0 Me gusta
No aplicable
I am not working with blocks.  I am inserting, pasting TIFF, JPEG into model space  and then creating views in paper space.  When I publish I get the pdf image below, there are balloons and other information on the drawing. I have performed this with other images and do not understand what has changed.  Some images are embedded and some have the path.  I know the embedded images do work correctly but not all of the time and the path images do not work.  I think I have changed some parameter some where and do not know where to look .  I am at a lost.
0 Me gusta
Alfred.NESWADBA
Inserting or pasting? These are 2 very different options (one creates a reference to the image file, the other creates an OLE object inside the dwg-file.
I would say the opposite, the OLE objects are the ones that create more issues when plotting.
If you think that you have changed parameters in the drawing then it does not help to show just gif files, uploading the dwg-file would give us the possibility to try it on our systems.
- alfred -
Alfred NESWADBA
0 Me gusta
No aplicable
I attached the file.  One of the comments deals with OLE and in my trials of pasting the image in the dialog box came and I said ok, did not work.
0 Me gusta
No aplicable
Some additional information, we normally use Publish to create  PDF's and if we have to print out the drawings we use Adobe, never use plot.
0 Me gusta
Alfred.NESWADBA
this is what I get when using _PUBLISH to PDF (not using background publish if this could make a difference).
I do not have your JPG file, so the PDF can't show this image, if you want that I test the same content then please upload the raster file too.
- alfred -
Alfred NESWADBA
0 Me gusta
No aplicable
I have attached the jpg file that is used in the drawing and I have also have a tiff file that is also used.
Thank You,
Keith Miller
0 Me gusta
Alfred.NESWADBA
please find my result ... seems all OK.
So we need to verify:
  • which version of AutoCAD are you using (command _ABOUT and attach a screenshot from this dialog)
  • please show a screenshot of your _PUBLISH dialog
- alfred -
Alfred NESWADBA
0 Me gusta
No aplicable
Have it figured out. It was a combination of the tiff was wrong which was not preventing the image to be embedded.
Thank You
