Anuncios
random mesh
a0985684202
random mesh
a0985684202
how to draw a 2D mesh of random shapes in Autocad? An example of the desired output is shown below.
0 Me gusta
Responder
317 Vistas
5 Respuestas
Respuestas (5)
Patchy
draw random points, use C3D and make TIN surface.
0 Me gusta
j.palmeL29YX
With a little LISP this should be possible (AutoCAD).
What I did (for testing):
- Create a number of random placed points (using a random number generator LISP)
- draw lines between these points (triangulate LISP)  (see on the left side in the dwg)
(- because the result of the  triangulate.lsp I used are 3DFaces I converted the faces into lines using the flatten command)
- put all the lines in a selection set
- delete randomly selected lines from the selection set .   => the result on the right side
I did not yet put this all in ONE LISP together, but I'm sure, if I repeat these steps I never will get the same result as shown in the attached example.
You can refine this idea to your needs.
Jürgen Palme
0 Me gusta
a0985684202
Could you please send your lisp code?
I know nothing about programming languages
0 Me gusta
Patchy
0 Me gusta
j.palmeL29YX
If that is true, the LISPs will be nearly worthless for you.
Nevertheless I post the 3 LISPs which I used in the attached zip.file.
Perhaps you can "play" with these, following this steps:
1.) load the mesh-test.lsp and run the command "test".
=> a number of randomly placed points in a 1x1 area are created
2.) load the triangulate-2.lsp and run the command "triangulate"
=> after selecting all in step 1 created points a bunch of 3dfaces is created
3.) run the command "flatten" (Express Tools) to convert the 3dfaces to lines.
4.) run the command "overkill" (Express Tools) to delete duplicate lines.
5.) load the del_lines.lsp
=> after selecting all lines (from step 4) a number of randomly selected lines are deleted.
6.) If necessary: Delete (manually) lines, which don't describe a closed area. (In the video were not such lines)
For demonstration a video:
Again: This suggestion above is far away from a final solution. But perhaps it helps you to refine this idea to your needs.
Jürgen Palme
0 Me gusta
