Radial Cobble Hatch Pattern
CentralmaineCAD
CentralmaineCAD
Does anyone know where I can find a radial cobble hatch pattern similar to what is shown in the attachment?
TIA!
Kent1Cooper
How would that repeat?  Hatch patterns are premised on the idea of repeating, like these somewhat related patterns:
Kent Cooper, AIA
arshadmirza786
May one out of 1000 help u
arshadmirza786
try FANCOB.pat
Michiel.Valcke
Here's an old .lsp in attachment from Larry Schiele which you can use to generate your own PAT files. Save them in a support folder path location and they will be found. But as @Kent1Cooper said, you have to determine how it will repeat. Hatches are repeating patterns.
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-install-cus...
https://help.autodesk.com/view/ACDLT/2024/ENU/?guid=GUID-2006ABDA-50C7-48FB-BBFC-B758C83F97FA
Pointdump
Hi Joe,
Welcome to the Autodesk Forums.
One interesting possibility would be a dynamic block. You might try posting in the >>>Dynamic Blocks Forum<<<.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
Kent1Cooper
@arshadmirza786 wrote:
try FANCOB.pat
That's the pattern used for the first of my images.  But I called it only "somewhat related" because it can't make what the OP shows in their image at Message 1.
Kent Cooper, AIA
