>> That adds an extra step more than just going up and changing the color
I don't see an extra step as the property window is also just move the cursor to the property window and change the property you'd like to change.
>> I'm just sketching up furniture so the accully layers aren't that important
This is one of the sentences which I see as wrong when thinking about structured CAD-files.
If you would not need to give the object a different color then the object could stay on the same layer.
If the object is different (where you assign a different color) the way to assign it to a different layer (and that layer has a different color) would be the much more structured way. And to change the layer or the color of an object is not more or less complex.
>> Now that I'm on 2021 at my new Job the Bycolor being greyed out
Well, I'm not sure how often I have to describe ... the field you describe that is greyed out IS NOT THE COLOR property, it's the "named plot style" property.
If you need the toolbars then please watch this very careful:
Hope it is more clear now ...
If you are missing one of the 4 pull-down selections then you have modified the menu and you need to reset it.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ...
blog.ish-solutions.at ...
LinkedIn ...
CDay 2025------------------------------------------------------------------------------------
(not an Autodesk consultant)
