Quick rotate and / or move-rotate
Message 1 of 8
I am after a couple command if anyone knows of one please, to:
1) Quick rotate text - in other words, simply click the text and click somewhere in space to rotate it. It will always automatically use it's insert point as the base point. and:
2) Quick move and rotate - similarly, select text, place somwhere, then click in space for it's orientation. Always using insert point as base point. IE without having to move/enter/select/enter/base point/destination/rotate/enter/base/rotation.
If anyone can help, that would certainly be great!
Thanks 🙂
Rroger_D
Replies (7)
Message 2 of 8
pendean
Community Legend
Community Legend
Grip editing: explore it in AutoCAD's HELP and in free tutorials on youtube and blogs all over the internet.
Or ask for help writing a lisp for both here http://forums.autodesk.com/t5/autocad-customization/ct-p/AutoCADTopic1
Message 3 of 8
steve216586
Look into the command MOCOR. It's pretty close to what you want. Click the text select the text base then move, copy or rotate multiple times, using that base.
"No one can make you feel inferior without your consent. "-Eleanor Roosevelt
Message 4 of 8
Jonathan3891
Something real quick I put together.
(defun c:MoveR (/ *error*)
   (defun *error* ( msg )
        (if (not (member msg '("Function cancelled" "quit / exit abort")))
            (princ (strcat "\nError: " msg))
        (princ)
(princ "\nMove & Rotate:\n")
(setq ss (ssget))
  (command "move" ss "" pause pause)
  (command "rotate" ss "" "@" pause)
(princ)
Jonathan Norton
Blog | Linkedin
Message 5 of 8
Jonathan3891
If you wanted to make it use only the insertion point, use this:
  (setq oldsnap (getvar 'osmode))	;store osmode
	(setvar 'osmode 64)		;set osmode insertion
        (princ)
(setq ss (ssget))
  (setvar 'osmode oldsnap)
(princ)
Jonathan Norton
Blog | Linkedin
Message 6 of 8
Kent1Cooper
[For anyone who finds this thread looking for this kind of function, be aware that the OP did take pendean's suggestion above, and posted the question over in the Customization Forum, where there are accepted Solutions.]
Kent Cooper, AIA
Message 7 of 8
wispoxy
(DTEXT already has an option to rotate)
Here’s how:
  • Start the MTEXT command T <enter>
  • Place the starting point for the MTEXT (note: if you are aligning the text to a straight object, snap to a point on that object.)
  • Before placing the second point that defines the text box width notice the options that you have in the command line. We will use the “Rotation” option.
  • R <enter>
  • Define the angle of the rotated text by either typing in an angle or snapping to an object.
  • Then define the width of the text box
  • Type the text
  • Exit the MTEXT editor by either CTRL + <enter> or by clicking outside of the text.
To move use the commands MOVE or M / ROTATE or R. Plus your can right click on text for extra options.
Message 8 of 8
Thanks to everyone who has spent the time in replying. As Kent1Cooper says, I did have the problem resolved elsewhere.
Apologies for not replying earlier, I have been away on my hols.
Many thanks.
Rroger_D
