quarter circle arc with specific length
Hello, can someone help me create an arc with these properties:
I know that the total length of the arc needs to be 12 mm and it needs to be QUARTER CIRCLE arc, so, I don't know what the exact radius is.
Thanks!
Alfred.NESWADBA
perimeter of a circle = diameter * PI
as you want to have a quarter of a circle then
length = diameter * PI / 4
as the length should be 12mm
12 = diameter * PI / 4
12 * 4 / PI = diameter
diameter = 48 / PI = 15.27887
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Thanks Alfred, but I was asking if there is a way to do this using the app's tools.
Alfred.NESWADBA
Did not understand the question in that way.
But yes, you can do it with the build in calculator (which is a tool inside AutoCAD too, isn't it?)
Other methods are much more complex (using parametric could be critical as there does not exist a direct method to access the arc-length), using LISP or the API could be an option too.
- alfred -
Alfred NESWADBA
I think I found a way to solve it.
I drew a circle with a random radius. I've selected it, opened the object properties window (Ctrl+1) and in the circumference field I typed 48. The circle radius will adjust to the new value and then I can trim it.
Alfred.NESWADBA
. alfred -
Alfred NESWADBA
