put hole part way though a cube
mark
mark
Im traying to put a hole part way thou a cube. I have made the cube and cylender and have alinged the cilender to the side of the cube. how to I attach the two faces togeather so I can remove the flat side of the cylender to make the hole? I want the vertices of the circle to attach to the cube side. I am trying to 3d print a simple bering. small cylender is the hole the big one is the shaft.
I have worked is maya 2008 and made several things for work but that was a wile agoe.
also I am able to scan objects int solidworks files .stl and I want to import them into autocad- what program would I use
Alfred.NESWADBA
Make sure your box and your cylinder are of type 3D-Solid, then run command _SUBTRACT (>>>details<<<)
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
