Purging Reg Apps in autocad drawing.
crdots87
crdots87
Hey does anybody else run into the issue of purging reg apps in AutoCAD. Then it says it purges out ACAD_OBJECT_CHANGE_GUID then when I come back into drawing a I do purge reg apps again and ACAD_OBJECT_CHANGE_GUID returns any suggestions?
0 Me gusta
Responder
344 Vistas
7 Respuestas
Respuestas (7)
cadffm
your product and productversion is?
you are saving the file in native format, or in an older one (which one)?
Xrefs attached?
Sebastian
0 Me gusta
crdots87
Autocad 2021 Product Version: r.172.0.0 Autocad 2021.1.3
No xrefs attached its 3D drawing.
0 Me gusta
cadffm
and
Sebastian
0 Me gusta
crdots87
I'm using an older template is that what you are referring to?
0 Me gusta
cadffm
No, but it's a good information too!
I asked about the file format (version) you are using.
dwg2018 is the native file format,
dwg2013 is an older format..
3D, so you are using 3dsolids?
Could be related to solid history.
Hmm
But hey, it isn't a problem.
Sebastian
0 Me gusta
pendean
Community Legend
Community Legend
May I ask, why is it important to get rid of that one single RegApp? Is it interfering with your DWG file or workflow by chance? Tell us more when you get a chance.
Is your DWG file totally devoid of blocks and 3D objects and anything other than lines, plines and arcs?
0 Me gusta
cadffm
I think you saving the file in an old .dwg Format.
Try this
Command: SAVEAS
Use a new name, to keep the original file
and change the file format to Autocad drawing deg 2018 format (Q: What is the default format in this moment before you set dwg2108 ?)
Try purge reg and save/close/ reopen the file
Still the same?
Sebastian
0 Me gusta
