Publishing Opens File a Second Time
jeremy.marcero7234
jeremy.marcero7234
I am running Publish from Sheet Set Manager, and I already have some of the files open in AutoCAD. When I do this, Publish utilizes the file that is already open to plot.
However when my co-worker does this, AutoCAD opens the file a second time (in the same CAD session) as read only. This causes the publish to take a much longer time.
I am pretty sure this is a system variable, but having an issue finding it.
Thanks for your help,
Jeremy
0 Me gusta
Responder
515 Vistas
4 Respuestas
Respuestas (4)
cadffm
Coworker publish in BACKGROUND, this is the issue and takes much more time.
Sebastian
0 Me gusta
pendean
Community Legend
Community Legend
.... AutoCAD does not let two folks use the same DWG file at the same time. Does C3D?
There is no "variable" for that, sorry. See above for a tip to use, be aware you might see performance even slower than before too.
0 Me gusta
WeTanks
AutoCAD does just that.
I can't find a system variable.
We.Tanks
A couple of Fusion improvement ideas that could your vote/support:
図面一括印刷
0 Me gusta
jamieq
I believe this is supposed to be the way AutoCAD works. Every version of AutoCAD I've used from 2005 up until 2021, when I published in the background a second instance of AutoCAD would open with the drawing I was publishing from and would then close when the operation was complete. It seems a similar thing is happening for you, except a second instance of the drawing is opening in the same instance of AutoCAD. Not exactly sure why it would do one over the other, but it's effectively the same thing, so long as you are able to use your drawing while the second instance of it is publishing.
Oddly, though, now that I am using AutoCAD 2023, when I publish in the background no second instance of either the drawing or the program is opened. That is, not visibly opened. I imagine it is opening a second instance somehow, as that is how background publishing works. But I don't see a new instance of AutoCAD open, nor is a new file tab added to my current instance like in your screenshot.
0 Me gusta
