Publish popup
Publish popup
KuriosCowboy
Publish popup
KuriosCowboy
I know this is a long shot, but here goes...
Is there any way to turn off the "hover-over" "help" popup in the Publish window? You all know the one; "Contains the list of drawing sheets to be included for publishing. ..."  It never fails that it's always over the part of the sheet name that I need to see to reorder the sheets, and it doesn't move/go away unless I completely move off the Publish window.
imadHabash
You may try to uncheck the boxes enabling Plot/Publish in background from OPTIONS command >> Plot and Publish Tab.
Imad Habash
KuriosCowboy
That's not exactly what I'm looking for.I'm looking to remove this:
pendean
Community Legend
Community Legend
If I may ask, how much hovering/loitering do you do that this is even a problem? Perhaps a video of you using it with a populated PUBLISH command might show something no one else over here is considering.
A screenshot of your ABOUT command would help too, as well as confirming your OS please.
KuriosCowboy
A Screencast vid of the issue:
https://autode.sk/3RNpDmt
I'm not exactly sure what you're looking for in the "About" except maybe version?
pendean
Community Legend
Community Legend
@KuriosCowboy You are missing an important update https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Update...
Thanks so much for the video too: that's not really as big a challenge as you state, but if you honestly find that too distracting to function, unchecking these boxes ought to do it for you but I haven't used R2018 in forever and it is too old for me to find on a computer over here to test for you
HTH
paullimapa
no....that notification seems to be built-in to the Publish command
Paul Li
IT Specialist
@The Office
