TL;DR I need to export Paper Space Layouts to DWG
actually exist the command PUBLISH and everyone can publish their layout to PDF, DWF, DWFx.
... Exist any method to export all my layouts in multiple separated files to DWG similar to PUBLISH command?
I mean, every layout as a unique drawing individually, merged or separated, similar to when is exported to PDF, if merged then separated for 2000 units each layout, if separated then with same that layout. and every layout should cut their XREF with XCLIP and exploded them, I mean every layout like individual drawing.
I already was searching for a different method, but 0 results, every lisp or tool that I found just export entire layout with their xref inserted.
I think you have answered your own question using xclip then chspace then wblock. Don't have anything. need to create clip boundary a fraction inside the mview window use chspace maybe.
I created one simple Script
-pdfimport
"C:\path-file-import.pdf"
5
8000,0
-pdfimport
6
10000,0
-pdfimport
7
12000,0
-pdfimport
8
14000,0
-pdfimport
9
16000,0
-pdfimport
10
18000,0
-pdfimport
11
0,2000
-pdfimport
12
2000,2000
-pdfimport
13
4000,2000
-pdfimport
14
6000,2000
-pdfimport
15
8000,2000
-pdfimport
16
10000,2000
-pdfimport
17
12000,2000
-pdfimport
18
14000,2000
-pdfimport
19
16000,2000
-pdfimport
20
18000,2000
-pdfimport
21
0,4000
-pdfimport
22
2000,4000
-pdfimport
23
4000,4000
-pdfimport
24
6000,4000
-pdfimport
25
8000,4000
-pdfimport
26
10000,4000
-pdfimport
27
12000,4000
-pdfimport
28
14000,4000
-pdfimport
29
16000,4000
-pdfimport
30
18000,4000
-pdfimport
31
0,6000
-pdfimport
32
2000,6000
-pdfimport
33
4000,6000
-pdfimport
34
6000,6000
-pdfimport
35
8000,6000
-pdfimport
36
10000,6000
-pdfimport
37
12000,6000
-pdfimport
38
14000,6000
-pdfimport
39
16000,6000
-pdfimport
40
18000,6000
-pdfimport
41
0,8000
-pdfimport
42
2000,8000
-pdfimport
43
4000,8000
-pdfimport
44
6000,8000
-pdfimport
45
8000,8000
-pdfimport
46
10000,8000
-pdfimport
47
12000,8000
-pdfimport
48
14000,8000
-pdfimport
49
16000,8000
-pdfimport
50
18000,8000
-pdfimport
51
0,10000
-pdfimport
52
2000,10000
-pdfimport
53
4000,10000
-pdfimport
54
6000,10000
-pdfimport
55
8000,10000
-pdfimport
56
10000,10000
-pdfimport
57
12000,10000
-pdfimport
58
14000,10000
-pdfimport
59
16000,10000
-pdfimport
60
18000,10000
-pdfimport
61
0,12000
-pdfimport
62
2000,12000
-pdfimport
63
4000,12000
-pdfimport
64
6000,12000
-pdfimport
65
8000,12000
-pdfimport
66
10000,12000
-pdfimport
67
12000,12000
-pdfimport
68
14000,12000
-pdfimport
69
16000,12000
-pdfimport
70
18000,12000
... this .scr import one pdf file, created with publish, to the current dwg file, work perfect, the problem is that is very very slow, took 4 hours to import 20 pages, then I was searching for alternatives, I was searching for a lisp similar to my script...
... is there a know it lisp to create xclip's of selected multiple layouts of multiple different drawings to my current drawing separated as my Script?
PD: @pendean why my post was deleted?, Am I being censored?, Did I say something wrong?
I did not understand you.
The first message you have about exporting using Publish.
The second is using a script to import.
What would you like ? Get from dwg - pdf or from pdf - dwg?
Maybe this will help you:
For import - AutoImportCAD
For printing in pdf - Revers
Have you tried our JTB LayoutsToDwg? We can customize it further to fit your specific needs.
Use the EXPORTLAYOUT command. It only exports one layout at a time and the resulting .dwg file contains the exported layout as a inserted block. Per this article: https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/Automati... there are Apps in the App Store that may perform multiple layout exports.
@JTBWorld wrote:Have you tried our JTB LayoutsToDwg? We can customize it further to fit your specific needs.
the first lisp that I tried was:
1 LayoutsToDwg
2 Layouts2Dwg
3 LXA
4 LXAv2
all of they are awesome for individual drawing with layouts, but:
1 and 2 just export same drawing with the unique layout.
3 and 4 cut the plan but have problems with xcliped block reference and external references.
... and 1,2,3 and 4 need to be modified for multiple drawings and layouts.
I tried to export with your method, but maybe I am misunderstanding? your method just works for PDF, DWF, DWFx.
If it wasn't too much trouble, could someone post a reference image of how to print to dwg?
@maratovich wrote:I did not understand you.
Both methods have the same result, I was searching for 3rd party software, but I did not found something similar and documentation, so I do not what software to test...
Your software looks interesting, I will test it soon.
@PatrickHughes wrote:Use the EXPORTLAYOUT command. It only exports one layout at a time and the resulting .dwg file contains the exported layout as a inserted block. Per this article: https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/Automati... there are Apps in the App Store that may perform multiple layout exports.
Thanks a lot for the suggestion, sadly I did not found the software or lisp or vbx that do what I did with my very simple script, all software I found was for individuals drawings, but no one of those apps have options to xclip to cut the drawing as the layout viewport.
... but I found Autodesk Export of Civil3D, do exactly what I need, the problem is that crash for some reason, and do not leave error info, so I do not what is wrong to repair in my drawing or maybe that just work with CIVIL3D files.
Add an example of your file.
We can customize our app to your needs. It currently creates separate drawings of each layout but if you want to batch process multiple drawings or anything else we can help.
The PUBLISH OPTIONS button here is where you set output results to single DWF/PDF file or individual DWF/PDF files
@maratovich wrote:Add an example of your file.
I attached a representation.
if I have a 3d model and Model views like this:
then I should show a layout representation like this:
