At work I have been trying to Publish a drawing in AutoCAD 2016. I am having trouble with the Publish Command.
I use the Publish command to plot multiple Layout Tabs, DWG to PDF. My 'VP Freeze,' seems to not be working. When the layout is finished publishing everything inside my viewport is not frozen like it should be.
In my layout tab and in plot preview the sheet shows as it should. Also, in the Layer Properties Manager the layers that should be frozen are frozen. Only whe it is finished publishing to a PDF everything that should be frozen is not frozen.
Any help would be much appreciated. I feel it is something as simple as a setting in the Publish command, but I cannot find it. I've Published many times before and this is the first of this issue.
