Publish Command Not Working
dany_rochefort
dany_rochefort
Are you having Publish problems ? Does the Publish window close after you hit the publish button and nothing happens ?
To solve the problem, you should have the correct page setup SAVED in the 1ST DRAWING of the BATCH you are trying to print. Then with all the drawings loaded in the publish window; Select All using CTRL+A, click on the first drawing PAGE SETUP and select your correct page setup manually, which will be propagated to the batch you are tying to print.
Don't "import" a page setup and don't use the "publish to PDF" options provided in the publish window.  These options are causing the problems. Dont get me wrong, sometimes these options DO work. And sometimes they dont... Hence why i am posting this comment.
john.vellek
Hi @dany_rochefort,
I have never had problems importing a page setup into a PUBLISH job.  Perhaps yours fails when you import one that no longer has a valid printer or plot style.
John Vellek
