publish 2 different viewports to 1 x 2 paged pdf file
MikeKovacik4928
Advisor Advisor
MikeKovacik4928
Hi all
Am trying the publish command to publish 2 different paper space layouts to one pdf file showing them both.
Keep getting the same layout published twice on page 1 and page 2.
Help and instructions required. I don't know what I am doing wrong
Mike Kovacik
South Africa
imadHabash
You may need to check PUBLISHCOLLATE (System Variable) . >> Click <<
Imad Habash
dany_rochefort
I can help you out,
Command: Publish
Hit the green + to add drawings (make sure you select include : layout)
Go to publish options : select multisheet file and specify save location
Page Setup set to : None
Publish to set to : PDF
Hit publish
step 1step 1step 2step 2step 3step 3
MikeKovacik4928
Dany
Mike
