Proxy error
Proxy error
stevetZ9EWK
Message 1 of 9
Proxy error
stevetZ9EWK
I have been sent a drawing that gives me errors when opening. i have researched and installed both the object enablers i found (civil3d_2021_oe_64bit) and (autocad_plant_3d_2021_object_enabler_english_win_64bit_dlm.sfx) but still get the error when opening the drawing.
Replies (8)
Message 2 of 9
imadHabash
 The proxy warning is for informational purposes. you can disable the Proxy Information window by PROXYNOTICE  system variable . also by PROXYSHOW system variable you can control the display of proxy objects in a drawing.
Imad Habash
Message 3 of 9
Alfred.NESWADBA
Can you please upload the dwg-file so we can look into it.
When the Civil 3D objectenabler is installed (and working), then this dialog should not appear.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 4 of 9
stevetZ9EWK
Good evening
Here is the file in question.
I am unsure if the enablers are working correctly but i  did install them. I have not tried to disable the message as i would rather work out what the problem is. I am not sure what will be left out of the drawing if i ignore or  click do not show proxy graphics. I am self taught and always learning so  do not understand the function of proxy graphics.
Regards
Steve
Message 5 of 9
Alfred.NESWADBA
I get a warning that the file contains macros, I don't load them (to risky).
But I do not get proxy warnings ... could you please start your AutoCAD, command _ABOUT and show us a screenshot from this dialog?
- alfred -
Alfred NESWADBA
Message 6 of 9
stevetZ9EWK
Here is the screenshot
Message 7 of 9
Alfred.NESWADBA
interesting thing, I do not understand what is really happening here.
I have installed the object enable in 2020 as well as 2021, both don't show this message.
I do not have installed the object enabler in 2018 and 2019, here I get the message.
By any chance, did the installation of the Civil 3D object enabler fail? What happens, if you restart this installer?
To your first post:
Just to make sure ... these are not errors, it's just an information about having some very specific objects inside your dwg-file, which might not be editable with default AutoCAD commands. So as long as you don't want to change these special objects, nothing to worry about.
You might start command -EXPORTTOAUTOCAD and create a new dwg-file without the proxies included. Run this command one time and use the drawing you get as result as your project file where you continue to work.
- alfred -
Alfred NESWADBA
Message 8 of 9
cadffm
I confirm
Without this OE -> Message appears as expected.
No problem with installed 2021 Civil3D EO
Sebastian
Message 9 of 9
stevetZ9EWK
Alfred
Good work you nailed it, for some reason the enabler did not install correctly. I did a repair and now the information window no longer pops up.But i did use the command you suggested so i will now use that file to see how i go.
Thanks for your help.
Reagrds
Steve
