Projecting side surface from a 3D object made by lofting in autocad into 2D
i have made a 3d object by lofting two circles in autocad:
PIC 1PIC 1
PIC 2PIC 2
JBBattery
Now I want to project the newly made side surface (without the two original circles) into 2D so I can make it with sheet metal. By projecting the side surface to 2D I mean something similar as when you project the side surface of a cone into a part of a circle.
schulz8NPAP
Do you mean something like this?
Regards
Jochen
Valentin_CAD
@Anonymous ,
Welcome to the AutoCAD forum.
The attached was taken from: https://forums.autodesk.com/t5/autocad-forum/create-flat-cone/td-p/3066880
Based on comments from @ToanDN and @Anonymous .
One your case, because the circles are not centered, make sure to draw the Arc from the longer side (so you don't get a "Results in zero length geometry" error when using the Lengthen command).
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
leeminardi
I think what you are looking for would be termed " the development of an oblique (offset) cone. "  A quick google searched provided some manual techniques including this link.  Note that since the cone is not regular the radial distance from the top to bottom edge varies.
lee.minardi
