Projectgeometry returns error
Karol-Or
Karol-Or
I want to extend the short pink line to the surface of the nearest solid, along the z axis.
I used Projectgeomentry but:
Modeling Operation Error:
Sweep self intersects.
john.vellek
HI @Karol-Or,
Can you instead just grab the endpoint grip of the pink line and drag it? I did this and drew a line that was aligned with the top face. I could then use fillet.
Or are you trying to truly PROJECT the line onto the face?
John Vellek
john.vellek
HI @Karol-Or,
I am checking back to see if my post helped you with your problem or question. Please mark a post or posts as accepted solutions if they resolved the issue or give me a bit more detail on this issue so we can continue to work towards getting this solved.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
